losing oil
hi i resently just bought a 944 tubo and i have lotice i am losing just a little bit of oil. i was wondering how common this is in 944's and should i be concernd. and if it is a problem how hard is it to change out the engine w/ a newer one.
kinda-sorta-normal depending on the amt. often it's the turbo's fault.
how much?
oh - and re: changing engines, it's quite easy (if you have DEEP pockets) - you're best off just fixing the cause.
how much?
Yeah, it happens to all of us. You'll notice the amount of oil you burn is closely related to how hard you drive the car. Just keep topping it off and you'll be fine.
