Wheels and tires suggestions
Originally Posted by divil
I just tried fitting my rear 9" wheels on the front to see if there would be any issues. For some reason on the front passenger side the wheel rubs against the spring a little, but it seems to be only in one place in it's rotation.
It has actually scraped the paint on the spring (2 horizontal lines between the 2 rust spots in this pic):
Has anyone else run into this issue? I don't have excessive negative camber or runout. I didn't try lowering the car with this wheel on the front but I presume the problem would be worse with the suspension compressed, right?
If you have any suggestions about other wheels I'm all ears though!
Right now I don't have any other wheels, and don't know what has been proven to work. I know some people have fitted rear CS wheels on the front (e.g. link from my previous post) but I don't know exactly what was different about their cars or what they had to change.
If I were in your position I’d pick up four factory 9x17 Cup 2 wheels (et55 iirc) with 275/40/17 tires. The wheels are plentiful and relatively cheap to buy and the choice of tires is much better in 17 than in your CS 16’s. 275’s will fit fine, I had the same setup on one of my cars a while back and it wasn’t an S so it didn’t have the added clearance of rolled fenders or smaller diameter springs.
Stagger them. Porsche did it for a reason, it also looks better. You can shift the fronts and rears from one side to the other. And why did you eliminate 18" rims?
That's a good point. I usually don't try to second guess the manufacturer. But I'm not happy with the way the car handles, so it's either change something or get a different car. I don't really care about the looks that much as long as it doesn't look ridiculous, which I don't think it will with a square setup. I've ruled out 18s because Porsche recommends not using them and I already find harshness of the car just barely tolerable as it is.
If you are not happy with front end grip there are other ways to improve that “understeer” than wider front tires.
Courtesy of Clark’s Garage (RIP)
Yeh don’t rely on rotating tires on the same axle, it further limits your tire choice and the best modern tires are directional anyway which cannot be rotated side-to-side.
Lifetime Member
Lifetime Member
You could buy my Porsche hollow spoke Technology wheels:
993 362 134 05, 7.5x18, ET50
993 362 140 01, 10x18, ET65
I ran them on m 1990 944 S2 until I changed to BBS RS-GTs in similar sizes.
Cheers.
Cheers.
True but, compared to the 911's I've been driving. 944's are much more direct turning in. They tend to suffer oversteer instead because the rear is much lighter. Where the 911 shoots out of corners much quicker due to the rear mounted engine.
Does anyone know if the clearance between the rim and the spring gets bigger or smaller when the suspension is extended fully (wheels off the ground)? What I'm concerned about is, if I get the wheel to fit with enough clearance when the car is off the ground, is it still possible it could rub at normal ride height or under compression?
divil (07-04-2019)
