need quick info on AR ration k26/6
I need info on the AR ratio of a stock K26/6 turbo from 951 (no S)
Also if you can give me the inlet size and exhaust, and what's on the tag (number, model.....) ?
Tanks, mine is to far under the snow ; )
Tanks
Tanks
http://www.bramall-turbo.com/FullAutoByMake_1Page8.html
It says K26 and maybe something else (don't remember) and on the next line it says: 86 935 2098. There are another group of numbers below that that say 5326 970 6720.
http://gallery.rennlist.com/gallery/albuq72/k26 This has the chart for the K26/6 that I scanned from an Excellence magazine.
Hope that helps! I'm not tearing that intake stuff off of mine again at the moment so I don't have measurements for you
Here are some mesurement i took last year when i got a k26/6 core.
K26/6 turbo spec’s.
Compressor housing :
ID intake 1-13/16’’
OD intake 2’’
OD outlet 2’’
Compressor wheel :
Inducer dim. 1-3/4’’ (44mm)
Major dim : 2-9/16’’ (64mm)
= 46.63 trim
Turbine housing :
Inlet ID 1-15/16’’
Outler ID 1-7/8’’
6cm2 = 0.366 cu in A/R .??? but in not sure about this. It seem pretty small.
Turbine wheel :
Exducer dim 2-7/16’’ ( 54mm)
Major dim. 1-7/8’’ (48mm)
= 59.17 trim
Hope this helps
K26/6 turbo spec’s.
ID intake 1-13/16’’
OD intake 2’’
OD outlet 2’’
Compressor wheel :
= 46.63 trim
Turbine housing :
Inlet ID 1-15/16’’
Outler ID 1-7/8’’
Turbine wheel :
= 59.17 trim
Hope this helps
