Dipstick does not go l the way down.
As title says, my dipstick does not go all the way down. Sticks out about 1/2 inch.
I searched archives and it appears there is an NA, 86 turbo and 87+ Turbo dipstick.
my car is an 87 turbo. The engine could be from a 86 turbo I’m not sure. Or perhaps the dipstick housing was swapped. Just saying it’s possible.
ive attached an image of the dipstick, can anyone tell which dipstick model this is?
thanks.
thanks.
thanks.
thanks.
its been a while and I may have had the same issue. the new style which you have won't fit in the old tube. I believe the yellow piece that goes into the top of the tube is too thick. you need the later tube as well
https://rennlist.com/forums/944-turb...fferences.html
PF and ekoz thank for the responses.
I was jamming it in, twisting it around and managed to get it a bit lower than before. Then it reached the plastic part of the handle and would not go any lower.
Appears I need to order an early model dipstick
So it’s an 87 951 with 86 engine or 86 dipstick housing. Maybe a few minor variations (like dipstick housing) were made between 86 and 87.
some pictures
some pictures
I’ve ordered an early model dipstick and guide tube from eBay. The dipstick design looks different. This should solve the issue.
Anyone know if the housing guide is interchangeable between 86 and 87+ 951 models?
https://www.ebay.com/itm/Porsche-924...b-52ed9479836c
Thanks for this post. I now have a new expression to use for people that I deem to be a little bit "off". Instead of saying that "his elevator doesn't go all the way to the top", I can use the new variant that you have provided, "his dipstick doesn't quite reach all the way to the bottom"!
Seriously, I hope you solve your problem!
Thanks. I’ll report back with what happens.
