Oil cooler sealant
Oil cooler sealant
Some sources say to use Curil T sealant on a new oil cooler housing gasket and seals.
As Curil T may be hard to find and/or take too long to get, what common substitute is durable and otherwise works well?
I never use any sealant. Installed 2 housings on different motors so far , no leaks. When you have a leak there it's usually from the groove in your housing out of tolerance due to erosion
I used this; it was easy to find locally here in Ontario. It was recommended--I forget where, sorry--as a Curil-T substitute. I remember it's popular in the air-cooled VW world. Seems to work great:
http://hylomar.com/hylomar-product-r...ing-compounds/
I bought the "M"
I bought the "M"
