Tie Rod Help! Cannot tighten!
Hello all,
I read up on changing the tie rod on my 1986 951. So I got one old tie rod out, no major problem. I ordered new tie rods (Lemforder brand, made in Germany etc...).
However, how do I tighten the tie rod part by the wheel?
The one I removed (maybe original) had a 19mm nut and a pin that was bent. I removed. The new one just has 19mm nut and no pinhole. Further, when I put the nut on the whole screw and ball eventually rotates. I have no way to hold it. I thought giving it same taps from underneath and then screw it in but that does nothing. Further the new one has some sort of screw that might be some sort of lock nut. However, I can get some turns on (about the screw height) but when beyond finger tight and need to use a wrench, it all just spins. I tried air-wrenching it on (lightly) but that did not work.
What is the trick?
What is the trick?
Hey mister,
Here is the trick: (after you verify it's some form of lock nut (probably a "stover" -which is pre distorted to really bite on the stud, which is a good thing but also the reason it's being a p.i.t.a.). Apply moderate pressure bellow the strongest parts of the tie rod; the ball-directly under the tie rod end. Apply about 1/4 the amount of force required to lift the car. If you are just starting to lift the one corner of the car, that's okay as long as the car is chocked & properly secured and the tie rod isn't being damaged. This might be enough. But if it's nut, then the speed of an air tool really helps suck it tight before it spins, then torqu accordingly and don't over torque.
Thanks! I googled and maybe it is a stover nut. I had thought about the put weight on it but did not try. I did try pushing it in by hand and tightening but did not help. Will try tonight!!!!!
Any other suggestions?
(the tie-rod was was trivial up and until tightening this nut...)
If the tie rod end still tries to rotate in the hole, go buy a conventional nut the same size and thread pitch as the tie rod end nut, one without a nylon insert or other locking mechanism in it. A conventional nut will not create the drag on the threads that the locking nut will and you should be able to go ahead and pull the pin up tight into the taper with it. Once the taper is tightly engaged, take the conventional nut off and install the lock nut in its place. Bingo, you are done.
Good luck
Peder
Put a floor jack directly under the tie rod end with a wooden block between, apply some pressure with the jack, tighten nut with impact.
You can cheat off early on the impact if you want to torque to spec.
T
T
Thanks all! I put a jack underneath and raise the control arm a bit, then used impact gun and it tightened. I am not sure to what spec but definitely tight as per the gun (and beyond 40 lbs because I tested it with that...)
Problem solved! I drove it and I got the alignment "almost" right....to the alignment shop we go...
Hello all,
What is the trick?
What is the trick?
Don't be shy, you need a bit of torque to overcome the nut (google nylock nut).
