Toggle type kill switch?
Can anyone explain how I can make a toggle type kill switch.
My car is alarmless right now, and I'd like some reassurance.
How would I go about wiring a kill switch to prevent the car from turning
on? Note, I'm looking for alternatives to pulling relays. I want a simple
switch that I can engage inside the cab easily. Thanks.
Does the car have a stock alarm? Sounds like it doesn't. What you need to to is find the power to the DME (I can get the pin number tomorrow) and put your switch in that line (thats how the stock 944 alarms work). No power to the DME and they will crank forever... Cutting DME power is the safest method.
Yeah, it does have the stock alarm. But, it has some sort of shortage, wheras if I try to turn the car on, the alarm will go off, and cut the ignition.
So I just pulled the power line going into the blue alarm brain.
