FS MO30 Strut Lock Rings & Perches
Are these for stock M030 springs and struts or aftermarket 2.5" springs on stock M030 struts?
They look stock but if they're for 2.5" springs I'll take em. Racers Edge use to carry such parts but are no longer available.
Thanks.
Thanks.
I also own one of the Racers Edge perches and the OD on that is 63mm or 2.48 inches. At 2.319 or approx. 59mm yours will fit a 2.5" spring but now i wonder if they fit the stock threaded sleeve on the M030 struts because there's aftermarket threaded collars out there that have a different pitch than the M030 collars. If you could post another pic with the inside diameter and a close up of the threads against a ruler so i could verify the thread pitch I would still consider them. Sorry for the trouble but I don't want to replace the collars on my M030 struts. If I can verify they fit the stock struts i'm probably still interested. Any pics of them installed on a car? Also good to know what you have there. Thanks again.
I put a caliper on the OD of my M030 threaded collars and they're roughly 61mm or 2.4". I hate to say it but I don't believe these perches will fit an M030 strut.
I'm going to have to pass on these.
Thanks, GLWS.
Thanks, GLWS.
