Lart's Fuel lines set of 3 special for listers
Old 11-19-2018, 01:54 PM
lart951
Basic Sponsor
lart951's Avatar
Default Lart's Fuel lines set of 3 special for listers
I have 4 sets left from last two dozen batch, 2 red/blue 2 black on black with the Teflon damper line on eBay $ 209.99 listers price $ 189.99 shipped in the conusaPorsche 86-89 951 944 Turbo, Braided Fuel Lines 3 PCS in Black with AN and pressure fittings set of two (3) pieces, includes 1) FPR Line, 2) Damper line 3) Small Damper/jumper line and a mini-pipe cutter and full instructions. The small damper/Jumper line is included.The Small damper/jumper line is a unique product from Larts, unlike the standard SS braided lines which are build with silicone (rubber) the jumper uses Teflon (PTFE) PTFE / Teflon with stainless steel has much greater chemical and pressure resistance compared to the stainless steel lines that have rubber on the inside. they are practically invincible.
PTFE is actually the same chemical compound as Teflon, but the word Teflon is owned by DuPont, which is why PTFE is a more common way of describing them.
Braided Stainless Steel PTFE / Teflon lines are great for replacing many factory rubber hoses such as rubber fuel lines, brake lines, and clutch lines. PTFE / Teflon does not deteriorate or bulge with age like rubber does, and has far superior chemical resistance. They carry a lifetime warranty.
Lines will fit;
944 Naturally Aspirated 1985.5 to 1988.944 Turbo 1986-1989
They won't fit 944S or 944S2
These lines not only meet but exceed all manufacturer specifications with a 300psi rating and multiple layer silicone hoses, they are the perfect match for modified or stock 944 NA & Turbo. Full color instructions with pictures are included as well as the mini pipe cutter.
Old 11-19-2018, 06:25 PM
NCLA951
NCLA951's Avatar
I HIGHLY recommend these. Luis when are you doing the read lines?!
Quick Reply: Lart's Fuel lines set of 3 special for listers
