Stock Turbocharger variants?
A good 60mm turbo can move enough air to feed 800 h.p. without a lot of effort.
On a 3 liter engine you could easily hit 350 h.p. If you can't hit 350 h.p. then you definitely need to work on head and cam design to allow the air to flow through without so much boost/heat creation as a result of the turbo being required to FORCE air in where it doesn't want to go.
AIR IN - AIR OUT.
AIR IN - AIR OUT.
