Complete high-performance exhaust and tuning solution for the Porsche 944 Turbo; includes Maxflo Exhaust System, Catbypass Pipe and Downtube, Turbo Outlet Top Pipe, BMC Air Filter, and DME Software Upgrade Kit.
Dramatically improve sports car sound and throttle response with upgraded Maxflo Mufflers and inlet tubing; includes Deluxe Outlet Tip
Fabspeed's Catbypass Pipe and Downtube for the Porsche 944 Turbo 951 increases exhaust flow from the headers to the mufflers and improving power and sound by replacing the catalytic converters with straight-through pipes
Fabspeed's Turbo Outlet Top Pipe is a high-performance turbo discharge pipe which replaces the failure-prone factory pipe that often collapses and restricts exhaust flow
Fits all Porsche 944 Turbo 951 vehicles (1985-1991)
Maxflo Exhaust System is constructed from heavy-duty 16ga T304L stainless steel that is a true 3.0” diameter from the catalytic converter out to the tip
Fabspeed's 944 Turbo exhaust components are all CNC mandrel-bent for accurate fitment and long-term durability
Catbypass Pipe and Downtube is a direct replacement for the stock catalytic converter/downtube which eliminates the very restrictive and unnecessary catalytic converter
Improved sports car sound and throttle response throughout the RPM range
Turbo Outlet Top Pipe is included to replace the failure-prone restrictive double-walled OEM pipe for increased turbo spool
Simple bolt-on installation
All Fabspeed performance products are backed by the Fabspeed Lifetime Limited Warranty
I have the exhaust components listed here, and they fit great and sound great. I just wish that Fabspeed made headers and the crossover pipe when I was in the market...
