regular and turbo stat tempuratures
I'm doing my belts water pump main seal pump gear and while i'm at it cam tower gaskets hope i don't have any more while i'm at its. I have a new 80 degree main thermostat and a new 83 degree turbo stat will I have any problems with a 3 degree difference, will my turbo stat still open and allow the turbo pump to pump coolant or will that 3 degrees cause my turbo to cook and shoot impeller parts into my ceramic coated exhaust ports?
3 deg. won't make any difference. You could block water off turbo alltogether and it would still work just fine. Water just super extends turbine life.
