On boost stumble - '86 Turbo
Old 06-12-2018, 10:17 PM
dsulliv6
6th Gear
dsulliv6's Avatar
Default On boost stumble - '86 Turbo
Hello - I get an on-boost fuel cut-off or stumble, but only in 4th and 5th gears at highway speeds. Car accelerates very well from stop, and from 1st through 3rd gears. When I'm driving at highway speeds, and get on the throttle in those higher gears, it feels like a rev limiter is trying to cut in intermittently. Loose connection? Fuel pump or filter gummed up and not able to maintain fuel flow at speed? Otherwise the car drives strong, and fantastic at all other speeds. At steady-state cruise on highway it's fine. Only when I get deeper into throttle in upper gears do I get this cut-off or stumble. Perplexed what it might be?
Any help with common fuel or rev limiter issues would be appreciated.
Cheers,
Dave
Old 06-13-2018, 08:38 AM
Humboldtgrin
Humboldtgrin's Avatar
Plug wires?
Old 06-13-2018, 11:09 AM
fast951
fast951's Avatar
If you are still runnig the stock DME chip, but you have a test pipe (in place of cat converter) or you altered any of the boost control functions then you could be hitting the overboost (overload) protection built in to the DME chip.
John
Email
www.vitesseracing.com
Old 06-13-2018, 01:13 PM
dsulliv6
6th Gear
dsulliv6's Avatar
Car is all-original OEM equipment, outside of replaced parts for service. No mods. AFAIK, OE replacement parts were used for servicing the vehicle in it's lifetime - and the copious records I was given with the car seem to indicate that's true.
If it was plug wires, wouldn't I get the stumble at all RPMs/gears? Only occurs at highway speeds.
Old 06-14-2018, 09:03 AM
87944turbo
87944turbo's Avatar
FWIW I had this issue with Magnecor wires. Went back to stock wires, problem solved. Just like yours, issue only presented itself under load at highway speed.
Quick Reply: On boost stumble - '86 Turbo
