Motor mounts replacement in a 951
Looking for advice from anyone who has replaced their motor mounts in a 944 Turbo.
I get a little extra vibration when I start the car. I figure it is my motor mounts. Mine is a 1986. I'd like to replace them, but I'm wondering how much of a pain in the a$$ it is.
The parts themselves look harmless enough and are fairly inexpensive.
I have done quite a bit of maintenance to cars in the past (including having done timing belt on the old 951 a couple of times). Can anyone tell me compared to doing the timing belt and balance shaft belt, how does replacing motor mounts compare to the timing belt job?
Also wondering what would it cost approximately to have a shop replace the motor mounts?
What I found was that I had to lower the whole crossmember as low as the bolts would go, then remove the bolts completely from one side. Then pry that side down and pop the engine mount out. The crossmember will rotate around the steering joint so it needs to be lowed at both ends.
When you're installing the new mounts, there's a lip on the top that fits into a little overhanging piece of the crossmember. Therefore the mount has to be compressed slightly and pulled outwards towards the side of the car. What I did was loop a piece of string around it, then compress it from the top with a pry bar and use the string to pull it into place. Obviously you need to have the crossmember bolts started before you do that.
The final challenge is getting the bolt holes lined up with the metal engine stands. This is tricky and you may have to experiment with raising the engine a little more or less on one side, or pushing it this way or that with a pry bar. Just keep the lower nut loose on the engine mount until the upper 2 are both in place.
There isn't really a definitive answer to that. Harder in what sense? It's physically harder for sure. You'll be under the car prying and wrestling with things. On the other hand it's a lot simpler. You don't need any great precision or attention to detail of the kind needed to change the timing belt. They're 2 completely different kinds of work.
Gotcha - thanks! I've seen a lot of people jack the engine up from the oilpan using a 2x4 between the oilpan and jack. ok, or not ok to do?
This item John was referring to is good if you don't have access to an engine lift. https://www.harborfreight.com/1000-l...bar-96524.html
I have seen people build these supports out of wood too, so that is a potential solution as well. 4x4 post is pretty cheap and would do the job.
It’s not an easy job but doable if you can follow instructions, spend a bunch of time working upside down on your back and can use some muscle for leverage. Most painful part of the whole job for me was having to do it again six months later because I did not use factory mounts the first time.
The hardest part I found was struggling with the lip that divil mentions in the first post. It's tricky getting it where it needs to go and getting the crossmember back. Pay attention to how the old mount fits. I did mine while doing the oil pan gasket; my mounts were completely destroyed but I had no noticeable symptoms before disassembling and seeing the shape they were in. Then once the new ones were in and the car was running, I never noticed a difference or any reduction in vibration, although my car has a louder exhaust and plenty of stiff suspension noises.
Few hints:
Buy the factory mounts. This isn't a job you want to do too frequently, and cheap aftermarket mounts seem to not last very long
I've raised my engine a few times by the pan. Not optimal, but no issues for me. You can also support the engine by placing a block of wood between the torque tube and body bracket (that crosses under the tube), just behind the bellhousing, once you get it lifted
A flex-head, ratcheting box end wrench was a big help
Thanks Jerome - that gives me hope. I have a set of those flex/ratchet box wrenches. I also recently bought a set of crow-foot wrenches in metric. So are you saying you'd stay away from the Hamburg-Technic motor mounts in favor of original Porsche mounts? The Hamburg-Technic are hydraulic.
ALL AFTERMARKET MOUNTS ARE INFERIOR TO THE FACTORY MOUNTS.
Doesn’t matter if they are hydraulic or solid they don’t work as good as the Porsche mounts and they don’t last as long as the Porsche mounts. Saying that many people fit them because they do not want to spend the money for genuine mounts, they don’t care about the extra vibration and they are willing to take the risk of having to change them again in six months.
