New (old 951) will only start with KLR 'jumped'
Hi Guys and Girls,
I hope some of you are as active with this forum as you used to be, I have learned so much from them, but I'm now stumped.
I have bought my 6th version of the 924/944 machines. This one is a 1988 951. (Started in the UK with a 924T, then 924S with Rover V8, then '86 944T here in Australia, then a '90 Turbo 'S'. then built a Carrera GT replica (my current track car) NOW my everyday '88 951
Sorry to ramble, but just wanted you to know I'm serious about these motors.
SO, the new toy won't start. No spark. Tried all the usual tests (reference sensors read fine, jumped the DME relay, checked all voltages and resistances from DME harness plug, checked continuity from DME plug to KLR plug. The car will ONLY start with the KLR bridged (pins 9 to 16)
Opened up the KLR (finding somebody in Australia with a known working example is 'tough' to say the least) found one or two 'maybe suspect connections, so re-soldered. My gut is the KLR unit is fine.
Car stopped almost like a fuel issue, after an uneventful 90 min drive, got home, left on drive and it just spluttered to a stop. Would not start again without the KLR bridged.
What I do notice is no movement from the factory boost gauge whilst trying to start, or when running in the bridged state. Pipe to KLR intact.
Car is unmodified. Alarm is bypassed.
ANY advice will be appreciated.
Your KLR box is bad/damaged or you could have a KLR chip gone bad. I have seen a few chips go bad for no reason (except age?). Try a different KLR chip first.
KLR #9 & #16 are the ignition input/output at the KLR for timing retardation purposes. If jumping them let's the car run then I would have to agree with Fast951 that there is an issue with the KLR, or the chip.
Thank you Tripl7. What I can't figure out is what sensors / inputs the KLR needs to operate? Any idea?
Still seems odd the boost gauge doesn't operate in the non starting situation.
That said, if you do a search for 'KLR pinout' here or on google you should get a picture of the connector with all the inputs and outputs labelled.
Check out page 29 of this official DME / KLR Test Plan: <a href="http://www.arnnworx.com/download/DME_KLR_Test_Plan.pdf">http://www.arnnworx.com/download/DME_KLR_Test_Plan.pdf</a> & test the input at KLR pin 24. Not sure what it is; it's called "Tri-signal", but looks like it needs that to run<br /><br />You'll need an oscilloscope though. EDIT: just remembered you can also use a 12v led (if it blinks while cranking, at least you see some signal)
Thanks John (I also own an E46 M3!), I'm sorry this will be my last post today as it's past midnight, but the question about inputs was due to a trial and error where I found if I disconnected one of either speed or reference sensors (sorry, tired and need to check which one) it would not start even in 'KLR jumped mode'. Are you confirming neither of these effect the KLR's operation? (Checked it's got power, but thank you, never assume!)
Yes those sensors go only to the DME, so without both of those you get no ignition signal at all.
Definitely KLR
Thanks Guys, I got the car to Buchanan Automotive in Balgolwa, near Sydney. Brice and Sean were fantastic and helped me confirm the KLR by plugging in their own test item. They did similar work to identify issues with Sunroof (Solenoid) & Heater Controls (Control Dash Unit)
Anybody have a working KLR for sale? Need to post to Sydney Australia.
Cheers again,
Mark.
Cheers again,
Mark.
