crankshaft stuck... holy sh!! HELP
Hi Tom,
Well the bolt came off quite easy. What does this bolt do except holding the outside pulley? I mentioned some freeplay in the main pulley, could this be caused by broken bearing?
The car is not in gear, at least I can turn the rear wheels. How can I check the clutch?
Thanks so far. Erik
Thanks so far. Erik
I don't have my manual with me but I put something on the front of the crank assembly backwards once, listened to my father, and managed to lock the engine. Took that piece off and reversed it and the crank rotated. Of course in your case you were able to rotate at first.
Alan C.
Alan C.
The bolt that holds the main pully on that is attached to the crank. The one you use to turn the motor by hand. That bolt is responisble for turning the oil pump. If that bolt is loose then your oil pump will either not function at all or not provide enough oil pressure at higher RPM's. This will cause catistrophic engine failure. The only (correct) way to tighten that bolt to the correct torque (~160 ftlbs) is to use a flywheel lock to keep the engine from turning. I have known of several engines that failed because that bolt was loose!
Alan C.
Alan C.
I could have started this thread! I am going through the same thing right now. It's still a mystery. My valve train moves fine but the bottom won't move for anything. We have the motor out and hope to find out this week what's holding everything up. We did scope the motor from the top and there was nothing in there. Maybe and oil pump seized - i have no idea. I'll keep you posted on what my findings are.
Originally posted by Erik T
Is it possible for the oil pump to get stuck and causes the crankshaft to seize?
Erik
Erik
Have you checked the orientation of the gear on the crank? If it is on backwards it can lock it up.
Erik, drain the engine oil and filter it through a coffee filter or a clean white cloth as it comes out, see if there are any metallic particles in it. If you pre-lubed the crank with motor oil there is a possibility that with a lot of cranking, one of the bearings on the crank has siezed. For you sake I hope not, but the condition of the oil should give you a clue as to what happened.
When you check the crank pulley the side of the gear with the lip should face out, the flat face of the gear goes against the washer and oil pump drive sleeve.
Tom,
Basicly tried everything posted up here. Took off the cylinderhead, poored some oil in the cylinders (so see if the pistons might have seized), pried with a large screwdriver to turn engine backwards... no succes so far.
Next thing is taking off the bellhouse (just to make sure there nothing jamming there). Do you know if I can move the bellhouse around just by removing the 4 bolts holding it to the enige and the ones (4) connecting the gear to the bellhouse? If there is a little freeplay to move around it will same me a lot of work. Otherwise it will be as much work as a clutch job.
Let you all know when I book some succes!
