Tming Belt Job 87 turbo
I plan on doing my own timing belt/cam belt/water pump job myself, my question is do you need the tensioning tool for this model if it has the automatic spring tensioners.
Thanks in advance.
Winter Project
Norm
Thanks in advance.
Winter Project
Norm
I would for peace of mind. The auto tensioners can be way off especially if the job hasn't been done for some time. I did one on an 88 that had been sitting for a couple of years and there was a big difference in tension before cleaning the tensioner and afterwards. So, I'd recommend cleaning the tensioner, and still using the tool to confirm.
Yes I would do the seals too. I replaced my waterpump last fall and didn't do the seals. It's leaking now.
I use the Kricket KR-1 tool to check the belt tension. It's available at NAPA stores for around $10 and once you learn how to use it, it's very consistent.
Change the seals, make sure to do the sleeves as well. The auto tensioner gets close enogh for a used belt but not for a new one. Besides you have to do the BaL. SHAFT BELT ANYWAY. stupid keyboard. I've never tried the kricket but something is better than nothing.
