Oil Pan leaking after new gasket
I just replaced my oil pan gasket and am starting to see some slow leaking at each end (round portion) any suggestions? I really don't want to redo it......worst job ever!
1988 951
Thanks!
1988 951
Thanks!
Quit Smokin'
I installed my pan gasket dry, no adhesive in the corners. I studded the majority of the block with inexpensive extra long metric studs. Pulled the studs out one by one as I swapped them for bolts during the install. Seems to have sealed well.
Is there any value in just using studs as the long term hardware? It would be easier to align and you would be guaranteed to have the gasket constrained around the whole perimeter during assembly. Plus, torquing is somewhat more consistent from nut to nut compared to using bolts.
Quit Smokin'
I installed studs in the block. They were not porsche parts, just generic studs. I didn't use 18 of them, but a handful, maybe 10. Put the gasket onto the studs, and it will hang in place on the engine. Then slip the pan up on to the studs. Then start putting bolts in. When you come to a stud, remove it, and replace the correct bolt. The studs are only to keep the gasket aligned and in place during installation.
Originally Posted by 87944turbo
I think there is so long as they are installed correctly. I have switched to studs from bolts in a number of applications with good results. Typically use ones that use an allen wrench for installation/removal. I Have always used good quality studs and checked the depth to ensure they are fully seated so that your not getting a false torque reading on the nut (i.e. you're not turning the nut and stud at the same time and using that reading). You have to take some care when installing whatever the related part is so that you don't damage the threads of the studs, but other than that it's pretty hard to go wrong.
I was thinking, also opens up the option to use loctite on the studs, and double-nut. Lock nuts would affect torque value obviously. That way there's less chance of them loosening up over time.
Update.....
Loosened and re-torqued per spec (diagram) and still leaks on front and rear. Only see the oil at the bottom of the radius ends (oil pump and clutch) Is there something above that could be leaking? Also is there a good way to detect with some kind of a light (black) ? My rear seal was replaced by a reputable Porsche mechanic and I replaced the front one on the main crank so I don't believe they the culprit. Any suggestions/opinions?
Update.....
