Head gasket and fresh head before turbo?
Old 02-14-2018, 05:04 PM
Dkritz944
Dkritz944's Avatar
Originally Posted by Auto_Werks 3.6
It bolts up to the stock crossover pipe. Mine has that taper machined into the hot housing, so it is basically a necessity to run a 3" down pipe. The turbo could probably be made for the stock down pipe, but that's certainly not going to help spool.
right. I wouldn’t even consider doing a bigger turbo with the stock DP. What do ya use on the cold side? LR j boot?? Is this a wet or dry turbo?
Old 02-14-2018, 05:13 PM
Dkritz944
Dkritz944's Avatar
I wonder if Evergreen could do some work on that super 61? New comp wheel? Hmm. I might ask him. Is your 61 wet or dry?
Old 02-14-2018, 09:10 PM
Auto_Werks 3.6
Quit Smokin'
Auto_Werks 3.6's Avatar
Both of the turbos are wet. Both setup to run 3" J pipe or maf tube. The k26 based unit is 100% bolt on, the super 61 you need to modify the water pipe that wraps over the top of the compressor. Id be happy to sell the 61, but I really think you'd be happier with something more modern from tim's shop.
Old 02-14-2018, 09:39 PM
Dkritz944
Dkritz944's Avatar
I apriciate the advice. And I’ll probably take it. Modern is prob the way to go. 👍🏼👍🏼
Quick Reply: Head gasket and fresh head before turbo?
