Flashers Issue - one side faster than the other
LHD 1986 Turbo. The left side flashes fast and the right side at a normal rate - that is,the same rate as the emergency flashers.
When you activate either flasher, the parking lights come on, not flashing, but the whole time the flashers are engaged.
I've replaced all bulbs in parking and flashers as well as cleaned all bulb bases and sides and also cleaned all earthpoints.
Can anyone suggest what I might try next?
“When you activate either flasher, the parking lights come on” - This is normal on most all German cars, it’s a safety feature when the car is parked curbside overnight.
I haven't swapped the relay so will try that, I was beginning to suspect the switch itself on the steering column - Ill check all the bulbs again as well.
Normal on German cars, did not know that .. thanks, at least I can stop chasing that one.
