Which brake proportioning valve for big red?
I've recently upgraded to big reds with cayenne 330mm rotors on the front of my 86 951, and left the stock brakes in the rear.
I run relatively hard suspension, and 255 semi slicks all round. At the moment I still have the stock 5/18 proportioning valve, and I'm trying to decide which one I should get to provide some more rear braking happening.
5/33
5/45
or an adjustable unit.
Ideally I'd like to get an adjustable unit, but I'd prefer the simpler install of the factory replacements.
What are your experiences?
5/33
5/45
Those fixed proportioning valves are fine for street/occational DE cars but when I raced I found that an adjustable valve was invaluable. One of the advantages is that you can adjust bias on the fly for changing conditions, such as a wet track, which you cannot do with a fixed bias. This isn’t my car but it’s how mine was plumbed in, it was simply taped into the rear line and extended though the floor.
Do you have to open the valve all the way every time you bleed the brakes?
I run 993TT front brakes and stock rears on my 951, and after some testing I found that the 5/33 valve works best for my car (@2750 lbs, with driver). The stock valve 5/18 was too front biased and the 5/45 was too rear.
