APE to Guru changeout
I received my Guru chip upgrade from Danno today, and hurriedly installed it (raining and all, need to clean out the garage, it's full of a boat, lawnmower, and motorcycles etc.). Only installation problems involved the hoses for the reliaboost. I ended up using some fuel line I had laying around to get it kink free. Peformance is much better; no off idle stumble, and pulls much harder to redline. Seems to be smoother and more responsive throughout the entire RPM range. At first the boost was hitting in a "stairstep" effect, kind of hit, pause,hit, pause, then hit and hold. I saw where other users had posted they'd seen the same thing, but mine went away after a few minutes driving. Overall a significant improvement. I'll install the wastegate shims next weekend, damn sure wasn't gonna lay in a wet driveway! Good job Danno!
Next up, exhaust!
Next up, exhaust!
then that would be a wastegate issue,i had the samething going until i put in an upgraded wastegate.also get a boost gauge once you put in the wastegate shimms.cause if you put it in now the boost gauge wouldn't be accurate because you have a weak wastegate.just my 2 cents
did you remove the restrictor in the banjo bolt (that came w/ the APEs)? i did the same swap and had same results (used an LBE instead of reliaboost).....much better performance but a midrange stumble. i'm pretty sure my issues is the wastegate being weak, i see the boost bleed of quick in the high rpms. i'm going to install a WG and testpipe so that should fix me up.
I was already running an LBE so that's not the issue. I spoke with danno yesterday, and he mentioned mid range richness, and said he was going to send me the version 9 chip as soon as he's done with testing. It goes almost completely away when the motor gets completely warm. I did notice yesterday when the motor is not completely to operating temp, it staggers a bit even when not on boost.
