Can this gauge be that off?
So, I'm using this new but ultra cheapo vacuum gauge homemade attachment to perform a post-AOS seals & vacuum line (plus Laust Manifold!) checkup:
The needle 'rests' (a bit shakey) between 10 & 15.
The motor runs fine, a little smoother and snappier than before (I replaced a leaky ICV, CV, throttle screw, and evap diaphram black circle thing) but according to this gauge, this test is medicore, correct?
Is it at least reacting properly?
I didn't do this before the project, checking for leaks with the compressor method instead. In fact, I've never performed a vacuum test of any kind before lol
I did find Tom's poll thread and most of you have 17+ at idle. I read that "high performance" engines may have low vacuum due to valve overlap. Does the 951 motor fall into this category?
Yes it can!
I managed to borrow a pro vacuum gauge and wow, is that cheapo thing ever off!
Hard to see, but the pro gauge is reading a solid 16 & very steady (the cheapo was reading about 12-13 and a little shakey)
Even the pro gauge can be read .5 to 1 hg different depending on the angle (at rest, depending how you hold it, the needle is either bang on zero or .5 either way)
I guess it's correct when they say the behaviour is more important than the actual reading lol
I've also included the dash reading
There ya go
There ya go
