Gear shifter issue
Gear shifter issue
When I let off the gas in gear the shifter jumps laterally to the left and when I step on the gas it jumps back to the right. I believe it is a tranny mount issue. I have a Xschop semi solid mount.
What could be causing this?
Normally, installing a semisolid tranny mount would solve, or at least reduce this sort of behavior. I filled my tranny mount with polyurethane and it solved the tranny twisting I was experiencing under load (was blowing out CV joints). Maybe your mount came loose?
Roger
Roger
Yep!
The know it all mechanic who installed the semi-solid mount did not tighten the nuts properly!
All good now.
