DME Relay?
Hi Mark,
just tested the coil with a 12V testlight. When I disconnect both wires from the coil and turn the ignition on, only the 15-ground has 12V. Nothing happening on the 1-ground, nor when I crank.
I guess this indicates the DME doesn't send a pulse... Think I should take out both sensors, clean them and check the space and try again.
Anyway thanks for the advise.
