What size injectors? X-Post
#91
read the instructions for installing guru chips, danno includes maps for different injector sizes. you just have to turn the FQS switch. quote from danno:
The FQS switch adjusts as follows:
FQS INJ IGNTION
#0 34.6lb 0 stock
#1 55.0lb 0
#2 65.0b 0
#3 75.0lb 0
#4 34.6lb 2.0 degrees retard
#5 55.0lb 2.0 degrees retard
#6 65.0lb 2.0 degrees retard
#7 75.0lb 2.0 degrees retard
FQS INJ IGNTION
#0 34.6lb 0 stock
#1 55.0lb 0
#2 65.0b 0
#3 75.0lb 0
#92
Well Mike, you will still need to modify the MAF signal to simulate the AFM signal for which the chip is designed. Get a piggy back or interceptor until Danno have made chips for a specific MAF.
By the way Danno, at what flow levels do the AFM bottom out?
Bengt
Bengt
