What size spacers to fit 16" phone dials over big reds?
It looks to be pretty close to fitting maybe only 5mm will do the trick. But figured someone already has done this.
Jeff
Jeff
Actually I am 99.9% sure that someone is running 951 Club Sport wheels with Big Reds. It is on of the companies that is on this list often.
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Well maybe that is what I have because the wheels fit over the rotor and caliper no problem. The interference is when the wheel is tight on the drum that the lugs inside the wheel hit the caliper. With spacers it should will run clear, just don't know what size.
You can run the big reds with the 16", however you need to machine the big reds (take materials off) or they will rub on the inside of the wheel.
Unless the machinist doing the work, already knows how much material is to be taken out. You are better off just getting 17"s..
