Taking engine apart for major upgrade
I'm upgrading to a guru 364 kit as soon as it comes out. I'm just wondering what should i do to my engine once it's apart. Nothing's wrong with my engine right know, but i want to make the engine as strong as possible so it doesn't blow with all that boost.
I'm thinking a new head gasket, port and polish the head, balance the engine etc. What else should i do? Remember my brother is a mechanic so labour is not a factor. I want everyone's opinion on this. Thanks, Leo |
It all depends what your goal is! Some day I want to pull mine apart because I have some minor leaks and it has over 120,000 miles. If the cylinder walls are good the I will just get the crank lightened cross drilled and then just basically all new bearings and seals as I put it back together. Oh yeah and of course new rings and head work. I hope my clutch holds out until I have a house with a garage to do this so I can go with a lightened flywheel and and all the other trick options with a new clutch and not have to do things more then once.
Did I miss something? I thought that the Guru "364 kit" was pretty much a dead horse, and haven't heard anything about it for a while.
Regards, |
If you are going to have your engine apart then do it right with a full rebuild. All seals/gaskets, rod bearing, main bearings, piston rings, wrist pins, water pump, oil cooler, oil pump, and balance shaft beaings. From start to finish it took me 2 weeks. With the help of your brother it may go quicker.
Christian |
