Greetings! ..also my first question
Hello new friends! My name is Jordan from Tuscaloosa, AL. Yesterday I purchased an 86 951, and I thoroughly enjoyed the 2.5 hour drive home! I have some technical background, but mostly from working on my MGB, an altogether more primitive machine. I will make an effort to search the forums for answers, but my first is a bit of a conundrum.
AC worked just before the PO bought the car, but he never made an effort to repair after the purchase. This is my first time diagnosing AC problems, and the only thing I have been able to determine is that the only fitting I can find seemed to have something plastic threaded inside of it, perhaps from previous work. I believe this is a new fitting, suggesting freon conversion. There was no cap, and I've only chewed up the plastic piece trying to get it out. I don't even know if this is the high or low side. Any pointers I can get from you would be awesome.
I'm looking forward to digging through threads as I take on small projects like this!
The one universally sold with the gauge has a blue quick connect plastic end.
Just get a new conversion fitting and forget digging it out, NAPA has 'em with a schrader valve kit,
T
That is the high side ac fitting in your photo by the brake resivoir. The low side fitting is under the car by the compressor. Looks like your high side has the 134a fitting. You can just replace that fitting or just leave it be. You don't need the high side to charge the system. It's only there for reference to see the difference in pressure from high to low side. You charge by the low side.
It can be a low side 134a fitting but it's on the high side. Both R12 fitting are the same size. But the low side R12 fitting is next to the compressor under the car.
Based on another photo I found elsewhere, it seems someone broke off the cap that was on this port. If I had a way to be totally sure there was no pressure in the system, I would probably just replace it.I might try digging it out, test the pressure, then see. Sigh.
It's not that bad. Just don't turn the 134a can upside down. You don't want to freeze the compressor. That would be bad. It takes a while to fill. Usually two smaller cans of 134a will do. On the top of the dryer there is a sight glass, when charging the system you want to charge it until the bubbles go away in the sight glass. That's a full charge. I would use 134a with a dye in it for one of the cans so it's easier to find leaks if you have some.
I'm going off of this page to determine that the low side is in fact by the strut tower:
http://forums.pelicanparts.com/porsc...-86-944-a.html
I also just used the following page's tip to turn the wheel and found the high side port on my compressor. It was not in the same place on the compressor, however, indicating to me that the ports are most likely correct.
https://coryoncars.wordpress.com/201...arging-the-ac/
I just need to dig that broken plastic out and try putting dye refrigerant in it. Can anyone tel me this: When under the car, I see a wire coming from above, to the rear of the compressor pulley, then what seems like another leader coming from behind the pulley to a spot on the compressor itself. Is this where I would feed 12v to test the clutch coil? I'm having trouble finding this wire from above.
The larger line of the two lines is the "low side." The smaller is the "high" side.
Confirm by tracing the line to the compressor. If the line goes to the drier (looks like a large beer can with fittings on it right behind the driver side headlight) then that's the high side.
"When under the car, I see a wire coming from above, to the rear of the compressor pulley, then what seems like another leader coming from behind the pulley to a spot on the compressor itself. Is this where I would feed 12v to test the clutch coil? I'm having trouble finding this wire from above."
This description sounds like the compressor clutch power. The other wire that goes to the compressor is the clutch ground.
You haven't told us how you are filling the system, but R-134a refrigerant connectors are different sizes and will not interchange. If you are using one of the quickie kits from a parts store, it is only going to go on one of the two fittings.
