hard to turn
hard to turn
My youngest son is driving our 87 944 na saying it was hard to turn to the left, told him to check fluid level and the belt. called a week later saying now it was hard to turn both ways when starting from a stop, once he was going it wasn't so bad. is it the power steering pump or is it the rack? any opinions greatly appreciated. (side note car is in Indiana and dad (the mechanic is in North Dakota, son is coming up for a week before returning to start Sr. yr. of college back in Indiana so want to get the right part(s) to repair). thanks and GOD BLESS.
bob
bob
you should be able to pick up dex II D at napa. fluid should be checked with the engine at idle.
hard to turn might also be...
1) low tire pressure (but this would not explain the left only symptom)
2) binding upper strut perch bearing. loaded, you are trying to twist the spring.
3) bad ball joint.
3) bad ball joint.
Belt intact? Clean fluid in the reservoir? Most likely the pump.
bob
bob
