944 & 944S Forum 1982-1991
Oil Question
Old 12-17-2017, 06:53 PM
Coloradoguy
Coloradoguy's Avatar
Default Oil Question
I know that questions of oil can spark flame wars like nothing else, but I'd just like some advice here.
Going through the records that came with my car, I see that the oil was changed at the following intervals:
122,423 miles GTX 10w-30
125,551 miles 5w-30 "Super Motor Oil" (I have no idea what this is, but at $2.50 a quart, I seriously doubt that it was synthetic.)
127,422 miles No type of oil specified on receipt
131,133 miles Mobil 1 0w-40 Synthetic
My car had just under 148,000 miles when I took possession of it and can find no other receipts for oil changes. I plan on changing the oil but my question is should I stick with the 0w-40 or go back to something like 10w-30 dino oil? I've read that using the Porsche-recommended 0w-40 could lead to oil leaks (I haven't noticed any) in a high-mileage car like mine. My car seems to start OK and the pressure hangs around the 3.5 bar level when warmed up. All opinions/comments welcomed and appreciated.
I live in Aurora, Colorado, and my car lives in a garage. Thanks.
Old 12-17-2017, 11:22 PM
Spring44
Spring44's Avatar
I am an original owner of an '84 944 and when these cars were new, most of the Porsche dealer shops used Castrol 20w-50 oil. In the late 1980's I switched to an independent porsche specialist shop to do my work and they switched me over to Valvoline 20w-50R Racing Oil.
I still use the Valvoline VR oil and the car now has 150k miles on it and it still runs great, doesn't smoke or use oil, and has 4-5 Bars of oil pressure at normal driving speeds. The reason that they liked the 20w-50 ValvolineVR at the shop is that it had more Zinc additives than other oils.
Old 12-18-2017, 11:24 AM
V2Rocket
Rainman
V2Rocket's Avatar
depends on the climate you drive the car in.
Colorado winter driver? 0-40 or 10-40 will probably suffice.
"warm weather" (aka 33 degrees and higher) 20W50...
Old 12-18-2017, 01:32 PM
Coloradoguy
What would you say to 5 quarts 20w-50 with one quart of Marvel Mystery Oil year round? Still too thick for winter driving? (I've always been a big fan of MMO, but have no experience with it in Porsches.)
Old 12-18-2017, 01:35 PM
Turbodan
Turbodan's Avatar
for the older porsche cars I like Brad Penn oil with high zinc content.
Old 12-18-2017, 01:55 PM
Coloradoguy
Thanks. I admit I had to look that brand up; I'd never heard of Brad Penn. I want something they stock at my local O'Reilly's so my choices may be somewhat limited.
Old 12-20-2017, 12:35 PM
V2Rocket
Rainman
V2Rocket's Avatar
WOULDN'T bother mix/match. if it's snowing, 0- or 10-w40 is fine.
also, you can get the same oil for cheaper from Walmart, FYI. like $12/5 qts rather than $22 or whatever Oreilly charges.
Old 12-27-2017, 02:10 AM
william_b_noble
william_b_noble's Avatar
I put over 250K miles on my 85.5, bought new, using "generic" 10/40 oil, changed every 3K miles. car was running fine when topgear USA bought it from me and destroyed it -(season 2, episode 2 I think). if you change at 3K miles you can use cheap oil and the engine stays happy. the car isn't hard on oil so you don't need the fancy stuff.
Old 12-31-2017, 09:28 PM
Want to be
Want to be's Avatar
You have a flat tappet engine and it requires ZDDP, aka - zinc.
Either you buy oil with zinc or use an additive.
Porsche has ZDDP oil forsale.
Amazon and Evilbay have multiple brands forsale. Buy a case of oil and a good Mahle or porsche filter.
Brad Penn, Kendal and other brands but find the one with zinc. You will not be able to buy it at Walmart, but I have found some Napa stores having an oil with high ZDDP .
Is my oil weight choices.
10/40 - winter
20/50 - Summer
I've always thought Zero weight oil is for modern cars. Goal to save gas not the car.
Old 01-02-2018, 01:36 PM
V2Rocket
Rainman
V2Rocket's Avatar
castrol gtx high mileage 20W50 has sufficient zddp levels (~1200ppm or so).
get a 5-qt jug at walmart for $12.
Old 01-05-2018, 12:06 AM
FHMotorsport
Former Vendor
FHMotorsport's Avatar
I would go with Millers Oils 10W50
Old 01-09-2018, 05:47 PM
Coloradoguy
Ended up going with 0W40 Mobil 1. That's what the PO had in there so I thought I'd keep it going.
Old 01-09-2018, 06:25 PM
FHMotorsport
Former Vendor
I would read this post too before I go with lightweight oils.
https://rennlist.com/forums/924-931-...t-reading.html
Old 01-13-2018, 02:41 PM
Coloradoguy
Food for thought.
I don't have a twin cam model and I don't race or push it hard.
On the other hand, I'm not really out driving that much in brutal winter conditions so I'm thinking of switching to 20w-50 just to be on the safe side. Thanks for the input.
Old 01-21-2018, 12:14 AM
jeffro951
jeffro951's Avatar
I use the 0-40 mobile as well, the one that says for European cars because it has zinc in it, it is available at all auto part stores.
Quick Reply: Oil Question
