Wiper motor problem.. 1987 NA
Okay, I think this is a motor problem, but we'll find out!
When I try to use wiper fluid if I pull the lever all the way the fluid is shot like 10 feet over the car lol!
Chances are that you just need to re-aim the nozzles- I've had good luck on other cars with using a very small pick or a straight pin to adjust them. Haven't had the occasion to adjust the ones on the 944 yet, but that's because washer fluid goes into the reservoir, then vanishes somewhere before you can use the sprayer...
