Headlight switch modification/Retrofit
I have a 84' 944 and i need to know what the numbers on the headlight switch are, had been diagnosing headlight problems when i tried to take the headlight switch apart i broke it and lost the little springs inside.
What i would like to do is put the lights and headlight housing motors on separate toggle switches because i have plenty.
I have looked for schematics, but if someone could help me through identify what numbers correlate with what function would be great.
Also i can either keep or get rid of the H/L beam Lever. I would like to just have the running lights and headlight on one switch or whatever will be easiest. I do not car about the dash being dim-able. I don't feel like waiting for a new switch to come in the mail.
Also neither of my low beams work, only the high beams, then my driver side high beam would go off and on so im looking for a short. i was diagnosing that when this switch problem happened. thanks!
