944 & 944S Forum 1982-1991
grinding noise from clutch/transmission area
Old 07-02-2013 | 02:44 AM
1985.1 944's Avatar
1985.1 944
Default grinding noise from clutch/transmission area
I stupidly did a burnout and instead of burning rubber the rear wheels seemed to bounce. Afterwards I heard a loud grinding noise from the tranny or clutch. When it idles and I'm pressing the clutch its normal but if I'm in neutral and let out the clutch its seems to grind/make a loud clattering noise. I can still shift into all gears and I drove it a little down the street but it sounds like the clutch is just spinning but its still engaged.
What do you guys think it is? I've got another transmission from the previous owner. But its sounding like clutch to me but I'm confused about how I can still drive and shift gears.
Old 07-02-2013 | 03:59 PM
931guru's Avatar
931guru
Drain the transmission fluid and check if you have shiny bits of metal. They would be parts of your ring and pinion...
Old 07-02-2013 | 05:53 PM
1985.1 944's Avatar
1985.1 944
I'm thinking throw out bearing. What do you guys think?
Old 07-03-2013 | 03:29 AM
1985.1 944's Avatar
1985.1 944
Or pilot bearing
Old 07-03-2013 | 09:41 AM
931guru's Avatar
931guru
Disconnect the trans to torque tube coupler and see if the noise is in the trans or in the clutch area.
Old 07-03-2013 | 11:52 PM
1985.1 944's Avatar
1985.1 944
Checked the fluid and its alright. It was a little low but I'm gonna put in fluid and see how it goes.
1985.1 944's Avatar
1985.1 944
How would I check the noise?
Quick Reply: grinding noise from clutch/transmission area
