Vibration Issue at 2000rpm
Hi All
My S2 has vibration at or around 2000rpm
It happens with or without clutch engagement.
Well while driving, it feels better sometime not noticeble.
What is the possible problem?
Could be quite a few
things...I had a similar
vibration when I had a
bad motor mount. Original
ones fail a lot on the
944. The fluid leaks out
eventually. Also,a bad
balance shaft is possible. Even suspension related issues could do it. Oh,
what fun...
what fun...
If you have a vibration after replacing the belts recheck the balance shaft belt timing - it is easy to get it off and the result is a buzzing that increases with rpm. These usually smooth out as they are revved. Bad motor mounts are usually most obvious at idle.
