FS - 88' 944S Street legal track car
SOLD!
Street legal track car. $10,000. Currently holds 12 class records for PCA San Diego Region. Some of the times for reference are: WSIR – 1:36.14; Chuckwalla CW – 2:03.83; Buttonwillow CW w/Star Mazda – 2.11.46. Auto Club Roval - 2:00.16. Numerous Top 10 AX and BRI finishes. Zone 8 legal for AX/DE/TT in CC06 or CC07 depending on tire configuration.
Engine - 2.5L 16V motor – Original engine was replaced with another stock used unit in May 2010. New main and rod bearings were installed along with a polished crank. New tensioner, pad and timing chain, and cams had already been replaced in January 2010. New timing belt and balance shaft belts, rollers and new factory water pump installed January, 2012. New Radiator installed January 2012. New fuel pump installed April 2012. Runs Lucas 20W-50W Race Only full synthetic oil, changed after every track event.
Drivetrain - New Clutch installed May 2011. Transmission and shifter are very smooth. Exhaust has a heat shield to protect the driver side CV joint.
Interior – stripped of carpet, headliner and interior panels. Door windows are removable Plexiglas.
Autopower roll bar, Sparco 5 point harnesses, Corbeau seats, Momo steering wheel with low profile quick release hub, G2X Data Acquisition. Cool Suit system with quick disconnect wires and switched at dash. Car can still be stripped of much more weight. Still has power headlights and mirrors. Currently weighs 2,775 Lbs with full load of fuel, no driver.
Suspension – Eibach 350 # front springs with adjustable spring perches, 28 mm rear torsion bars, rebuilt extended ball joints, Koni yellow adjustable shocks at all four corners, 968 MO30 front sway bar with triangulated supports, Weltmeister rear adjustable sway bar. Racer’s Edge adjustable camber plates, corner balanced and aligned. Car is dialed in and very fast. Car also has brake cooling ducts coming from the front valance to cooling backing plates.
Full price includes the following or price is negotiable without some or all of the following:
3 Sets of Wheels/Tires – one set of 16 x 8 968 wheels and one set of 16 x 8 D90 wheels with 245/45/16 Hankook Z214 C51 tires. One set of 17 x 8.5 wheels with 255/40/17 Nitto NT01 tires.
Spares – Engine with 16 valve head in good shape. Bottom end needs rebuild (spun #2 rod bearing).
Miscellaneous parts such as wiring harness, exhaust with cat, headers, air cleaner, gaskets, cut off switch (never installed), DME with chip, Alternator, power steering pump, ICV, etc., etc., etc.
Call Mark at (858)864-3163 or email mrondeau@***.net for pictures
Open to offers for just the car with one or two sets of wheels.
Still for sale. Waiting for a few people to either sell their current cars or make a final decision. Accepting offers on just the car with up to three sets of wheels and/or the spares including a 16V head in great condition and lots of 944S parts.
