944 & 944S Forum 1982-1991
throttle response cam
Old May 16, 2002 | 11:21 AM
84red944's Avatar
84red944
Post throttle response cam
I see and hear a lot about throttle response cams. Does anyone have one and are they worth buying?
Old May 16, 2002 | 04:11 PM
rplencne's Avatar
rplencne
Post
It will give you a better feel for the throttle than the stock part. Just about everybody who sells Porsche aftermarket stuff will carry them. It should cost you about $35 (Paragon).
-Bob P.
Old May 16, 2002 | 07:54 PM
snappy's Avatar
snappy
Post
it chages the throttle response to a 1:1 ratio. so your pedal distance will actually be shorter. it's quick and easy to install helps if you have a second person to push the pedal all the way down so you can set the tention on the cable and the pedal stop inside the car. beware that this does increaase fuel consumtion as you are way more likely to "floor" it. Surf arround a bit you could pick one up for arround $20 with shipping
Old May 16, 2002 | 09:32 PM
ERAU-944's Avatar
ERAU-944
Talking
i've got one and if i am nice, i get 27 MPG combined city and hwy driving after like 350 miles. i like it, but its easier to match rpms without it.
Old May 16, 2002 | 10:38 PM
Fred H's Avatar
Fred H
Post
Is a throttle response cam available for the 944 S2?
The listings I have run across have specifically excluded the S2 but I have not yet found a specific reason for this exclusion.
Fred
Old May 18, 2002 | 04:15 AM
Skip's Avatar
Skip
Post
Not for the S2 or Turbo - the throttle cam profile on those cars is already linear (the effect of the round throttle cam)
Old May 18, 2002 | 08:30 PM
Super 44's Avatar
Super 44
Post
The same is true of the 944S as well correct? That the throttle cam already has a linear ratio? I was looking to do the swap but someone told me it wasn't necessary because of the current cam's profile
