odometer question
so far i have changed the sensor on the trans and the odometer gear. the speedo works. do i assume not the odometer motor is stuck or bad? what else do i need to check for functionality? many thanks for any advise
My gear was bad as well. after replacing still had the same problem. What I found was the gears were miss aligned. I had to make a nylon washer to fit between the gears to keep pressure on the worm gear. Has worked ever since.
