WANTED: 944 S2 Cabriolet window seals
Good afternoon folks! I'm looking to see if someone here has the seals that go around the window for a 944 cabriolet.
At minimum, I need the vertical seals both inner and outer and the metal sled that they are seated in for the drive side. The B pillar, if you will? AND the outer horizontal seal that goes across the top on that same side. If you have more or less these items still, let me know. Thanks all!
