Can someone identify this fuel line? (PIC)
Hey guys, I'm new to the 944 and I've tried searching the parts catalogs but I haven't had much luck in finding what part this is. I have a small tear in the hose and it's leaking fuel. I figured I would have to replace the whole unit. Any help would be great!
![](http://i631.photobucket.com/albums/uu38/uffitz56/14-Engine.jpg?t=1312762310)
I initially thought it was this: http://www.pelicanparts.com/cgi-bin/...2C%20944%20%20
But that looks like the bottom hose....Thanks guys!
Pressure hose to the fuel pressure regulator , Make sure when looking it up your in the 83-85 it is different after 85.5. Also that short hose that loops around forward and opposite side of that one should also be changed it is the cause of many a burnt 944. T
Been awhile since working on an early car . but that line looks odd , seems as if someone has tried to remake it , has some crimped fittings that look new and added, to many connections there. the line should come apart just under the car and have about a foot of hose at the fuel regulator. Look at 944 ONLINE at the fuel area there is a picture and a diagram that show a little bit of the way it should be.
On the later cars the fuel lines come from the passenger side , across the hot exhaust , never made good sense to me .
So anyone know where to source this part? I am still having a hard time finding it. Maybe I can find someone local to just crimp on a new hose? Took the hose off today...
Thanks!
Thanks!
![](http://i631.photobucket.com/albums/uu38/uffitz56/IMAG0138.jpg?t=1312838514)
![Lightbulb](https://rennlist.com/forums/images/icons/icon3.gif)
Hi I might be able to help you! Original PET Factory File in PDF format complete with part numbers and Diagrams for your car.... Let me know Year, Model, and if US/CND or grey market and I can email you the File.... thom.ruben@gmail.com
