944 & 944S Forum 1982-1991
How do your turn 944 engine by hand?
Old 06-04-2011, 09:13 PM
Varoom69
7th Gear
Varoom69's Avatar
Unhappy How do your turn 944 engine by hand?
While trying to clean battery cable ground above clutch housing, the nut fell into the opening for the clutch housing. I have removed the starter hoping the nut fell down into the bottom of the housing, not so lucky.
So, how do I turn the engine by hand in hopes the nut will fall down to the bottom and I can remove it. Afraid to turn engine with starter in fear of major damage.
Anyone else out there do something this dumb??!!
Old 06-05-2011, 03:02 AM
Reimu
Reimu's Avatar
there's a big nut on the front of the crankshaft you can turn with a wrench. It's like 23mm or something.
Old 06-05-2011, 03:11 AM
thirdgenbird
thirdgenbird's Avatar
24mm
a deep well works best but there is not much room for a ratchet.
Old 06-05-2011, 04:58 AM
JakeS2
JakeS2's Avatar
You need a 24mm socket and the some force.. If you need to rotate the engine quite a bit I'd suggest to take off your spark plugs.. A cheap (sub $100) endoscope might be of use also for inspecting internals of bellhousing.
one the final question : TONS of it. These things usually happen when something you planned did not work out so you take it apart, fix something and put it back.. and then realize something was left out, take it all apart (3AM) and then bloody eyes put it back together...
Old 06-06-2011, 05:42 PM
Varoom69
7th Gear
Varoom69's Avatar
Default Done. Thanks ! Now back to the dead instruments issue.
The nut fell out after the first quarter-turn rotation. Wheeeeew! Put all back together and cleaned negative battery ground and another ground adjacent to it. Still no instruments. Cleaned the grounds on each side of the top engine compartment also. All fuses check good.
Any other ideas? Starts and runs good, just no instruments, tach, or speedometer. Panel lights ok.
Old 06-07-2011, 11:00 AM
pnbell
pnbell's Avatar
There are grounds on the back of the Instrument Panel that could need a good cleaning too..
Except Tach and Speed, do the other gauges works?
Old 06-07-2011, 01:05 PM
Varoom69
7th Gear
Varoom69's Avatar
Only a faint red battery light at the bottom of the voltometer gauge when starting. Otherwise, all dead. No movement whatsoever during ON/START/IGNITION.
Quick Reply: How do your turn 944 engine by hand?
