Just bought a 87' 944 na, looking to drop $6500 HELP
Body roll - how old are your shocks? Those may need replacing, also may want bigger swaybars (should adjust fronts accordingly to maintain balance). Have you done any suspension work?
I'm curious how you like those headlights. Are they pretty good? Also did you recover the dash yourself? Suede? Faux suede? Alcantara? Another tip - you may want a rubber shift boot on your shifter or you're going to get a ton of heat transfer, and also as a safety thing.. But maybe thats an 'in progress' photo.
Nice work! Did you do the painting?
Drive safe, have a good one!
no suspension work yet.
What would a guru recommend for stock height in the rear but stiffer so when cornering the wheel doesn't rub go up and rub on the outer inside fender wheel?
Thanks and yeah I got a tatty shift boot just until I can afford short shift, with a nice **** and boot. After the suspension work.
Love the dash. But here's a little advice, send Lart a pm and get some parts for interior. All those small hard to find pieces you will need to finish her up.Lart,JoshB.- trust me, you can thank RL later. Oh, and why not become a member? You will see the benifits of it after you save a boatload here.
Nice work on the car, although the tinted tail lights and rims aren't my taste, I think you did a good job of execution. I think you would be better off without the HIDs, they don't suite the style of the car well and the upgrades for stock lighting are going to be better. Dashwork looks amazing.
Great work on the dash. I would love to have something similar at some point. Not what I would have chosen for a wheel tire combo and I despise those headlights, but its your car and you can do what you want with it. At the very least, wheels and headlights are probably the easiest things to switch in and out on these cars if you end up changing your mind/seeing the light.
