NO START
NO START
have gone throught everthing on this forum about no start, I am at the speed and reference sensor's now. Did an ohms test on both and get a reading of 1079/1080 on pins 8/27, and 25/26. On pins 8/23 and 25/78 I am not getting a reading at all.This is with the sensor's out of the car.
It seams strange that both would go out at the same time.
I am not getting a reading on the Tach, when trying to start, but then again I don't trust the tack, as it has not worked on occasions.
Should I try to get some new sensors.
hando
hando
From: Hawkinsville / Perry, Georgia, RETIRED USAF GO BLUE
Hi Hondo, Check out the link below. You can use the BMW Reference/Speed Sensor Part Number 12-14-1-708-619 as it is cheaper than the Porsche one. It just has a longer wire.
http://www.clarks-garage.com/shop-manual/ign-02.htm
Cheers,
Larry
Cheers,
Larry
