1986 Porsche 944 Clutch Master and Slave
Location: Hawkinsville / Perry, Georgia, RETIRED USAF GO BLUE
1 Post
If you can afford the down time, check the slave cyl for pits on piston. If it is OK you can save by rebuilding it. Buy a new Master and the line going from Master to Slave as they deteriorate from the inside. Check out price at 944online.com and Pelican Parts. Be sure to bench bleed the Master before installing.
Cheers,
Larry
Cheers,
Larry
