Lowering the suspension
I would like to install a pair of Koni struts with a set of weltmeister 200lb springs but without the spacers.
I understand this will lower my front end by about 1 1/4".
If I lower the front end is it necessary to lower the rear end too?
And if so how do you do lower the rear?
Regards,Severian
Regards,Severian
On the Radar
You can lower the rear by adjusting the spring plates.
You should get between 1/2" to 3/4" lower. Any lower will require reindexing the torsion bars.
The adjustmaent procedure can be found on clarks-garge.com
