944 & 944S Forum 1982-1991
Will not idle
Old 04-23-2009, 12:32 AM
drfergus
drfergus's Avatar
Default Will not idle
Hi,
My 1985.5 944 just started last week not holding an idle and dying after starting.
I have replaced the coil, spark plugs and spark plug cables.
HAs anyone else had this problem before?
Any ideas I am willing to try.
http://ferguson-ranch.hobby-site.com/Porsche944A.htm
Thanks,
Dana
Old 04-24-2009, 04:59 PM
peanut
peanut's Avatar
your best bet would be to post this on a more popular forum like the water cooled board or failing that have a look on the Clarks Garage website in the workshop manual section . There is very good troubleshooting guide for this problem.
here is the relevant section from the Clarks website .
Running Problems
1. Rough Idle
1. If the car starts when cold but, idles rough or does not want to stay running, this can indicate a problem with the engine temperature sensor. When the engine is started cold, the engine temperature sensor sends a signal to the DME control unit to provide a richer mixture. As the engine temperature sensor starts to fail, it sends a higher than actual temperature signal to the DME control unit. The DME control unit leans the fuel mixture thinking the engine is at normal operating temperature. This causes the engine to run rough. As the engine warms, it not longer needs the richer cold idle mixture and the engine runs smoother.
2. If the car idles rough this can also be indicative of bad plug wires, distributor, or rotor. One way to check for bad plug wires is to inspect the plug wire runs with the car running in a very dark area. If the plug wires are bad you should see some arching to the cylinder head or fuel rail.
3. If the car idles rough or cuts off at low RPM or idle, the cause could be a failing O2 sensor. The O2 sensor is out of the loop at full throttle and will not affect the way the car runs.
4. A rough idle can also be caused by a problem with the air flow box. The damper for the air flow box can fail mechanically or the contacts inside the box can get dirty and send a errant signal to the DME control unit. This can sometimes be corrected by cleaning the electrical contacts inside the air box. This requires removing the cover on the air box which is held in place by caulk. You will need to cut through the caulk and gently pry the cover off. Once the cover is removed, clean the circuit board inside with a good contact cleaner. When you have finished cleaning the circuit board, reattach the cover using a non-corrosive caulk.
5. If the car experiences a rough idle or idle fluctuates several hundred RPM, this can indicate a sticking idle stabilizer valve. Many people have removed and cleaned them but, this is normally a temporary fix and the valve should be replaced. A faulty O2 sensor can also cause RPM to fluctuate at idle. Unplug the O2 sensor and see if the idle still fluctuates.
Quick Reply: Will not idle
