Wet Floor Board
I have 2 83 944's with the same problem. After a rain storm the passenger side rear floor board turns into a swimming pool. I looked every were for water marks but cant find any. Has any one experienced this problem and if so how did you fix it? Thanks for the help!!
Yes, I had the same problem. It was traced finally to a sunroof leak that ran down behind the headlining and finally ended up behind the dash.
It caused a lot of corrosion to the DME box that sits behind the floorboard, so it is wise to get it fixed soon!
How was this fixed? It is a matter of the drain channels being clogged for the roof, or was it a case of there not being a good enough seal and water was just leaking in? This -just- started in my car, too. Wet floorboard, no indication of water drip on the inside, and can't seem to find any other leaking points...
I had a similar problem on my 85.5 NA. I used one of those things you use to suck boogers out of a babies nose and applied a few drops of drain-o into each drain hose.
Marcus
Marcus
