944 & 944S Forum 1982-1991
Vibration problem??
Old 02-07-2009 | 01:11 PM
scottstanley944's Avatar
scottstanley944
Cruisin'
Default Vibration problem??
Hi guys and gals..!
im after some knowledge on a vibrating issue that my 87 NA 944 has.
at certain stages of revs e.g. 1500rpm & 4000 rpm i get feedback through the steering wheel making an awful sounding vibrating noise.
i researched this on the net the other day, and read up about the balance belts and how they can miss align. so i spent all of this morning checking and one of the teeth on the lower balance pulley was out. so i corrected this n put the car back together again hoping this will have solved the problem!
but sadly no i start to drive it home an dthe vibration is still there.
can anyone suggest anythin to try?
thanks in advance!
scott
Old 02-07-2009 | 10:20 PM
J Berk's Avatar
J Berk
try posting this in the 924/44/68 forum under WATERCOOLED...you'll get plenty of responses there.
Quick Reply: Vibration problem??
