944 & 944S Forum 1982-1991
Car won't start. God help me....
Old 01-23-2009, 05:47 PM
MrTom
MrTom's Avatar
Default Car won't start. God help me....
Well after months of battle, I go to move it into the driveway, no start. This is how it went down.
Checked all fluids. Good
I attach battery jumper box. The cooling fan turns on(key was on POS2).
I get in, turn the key, and everything shuts down. No warning lights, no clicking, nothing. Now I can't get it to do anything. I looked at the fuse cover, I cannot figure out what fuse would cause this. And how do I check each relay? I can't listen for a click because where the fuse box is, the ignition is too close. I end up hearing the key clicking. Did I fry something?
What and how do I check?
tom
Old 01-27-2009, 11:06 AM
MrTom
MrTom's Avatar
well thank you....
Old 01-27-2009, 08:15 PM
smlporsche
smlporsche's Avatar
Tom-
Sorry I can't help you. Maybe you should post it on the 944 part of the water cooled section...
Old 01-28-2009, 07:33 PM
Pcar944
Pcar944's Avatar
Originally Posted by smlporsche
Tom-
Yes! Post in the: 924/931/944/951/968 Forum
Nobody ever comes in here... not sure why its even here.
Old 01-28-2009, 08:10 PM
RolexNJ
RolexNJ's Avatar
Tom, make a new post in the forum below, you will get a lot more responses over there.
https://rennlist.com/forums/944-turb...bo-s-forum-72/
Old 02-28-2009, 05:50 AM
peanut
peanut's Avatar
sounds like the ignition switch assembly may have died. Suggest you detach connector and connect to a spare ignition switch and test that
Quick Reply: Car won't start. God help me....
