83 944 spark plug wire firing order connections
![Red face](https://rennlist.com/forums/images/icons/icon11.gif)
I was changing the plug wires and like a dip I didn't take them all off one a time and now I'm all mixed up, it's only a 4cyl car you'd think I could figure it out. Anyone got a firing order spark plug wire pattern to the distributor? thanks
Firing order is available here:
http://www.pelicanparts.com/944/tech...ine_specs1.htm
Determining when dizzy is on #1 can be accomplished by removing #1 sparkplug and determining TDC of compression stroke (plug the the hole and feel for pressure). Never done this myself yet on a 944; depth of plug hole may require some creativity.
Once you know where on the cap #1 is just put them on in a CCW order (1-3-4-2), that is the universal 4cyl firing order (only a few odd ***** that don't follow this)
